Steam Radiator Replacement
NewbieInQueens
Member Posts: 25
Hi all, had a question about radiators. Most of the radiators on my 1-pipe steam system are the cast iron old style column radiators. I also had some new ones installed that are the new from the plumbing supply shop thin tube, like these: http://governaleindustries.com/products/gov-free/
Maybe it's my imagination, but are those old radiators better at putting out heat than the new ones you can buy now? I figured if they are both cast iron and have the same EDR rating, they should heat the same, but to me it seems like they don't.
Curious to hear thoughts on this,
thanks and Happy New Year to everyone,
They may not. But not because they don't have the same EDR rating. One factor may be colour and finish. Dull finishes put out more heat than gloss ones, and much more than pure metal or metallic finishes.
The other factor is pure weight. The heavier radiator will heat up less rapidly, but that is rarely noticed. What is noticed is that the heavier radiator will also cool down much more slowly -- and you will feel the warmth from it for a long time.Br. Jamie, osb
I'm sure the old radiators have thicker walls. I would think the greater the mass the better the condensing/ heat emissions and the longer they hold and release heat, after the boiler has shut down0
I have old tube style radiators from 1930s at my house. When I got brand new thin tube/slenderized radiator I wasn't happy with it. The new one is lighter and does not retain heat as long as my original ones. Also narrow sections are restrictive and it is harder to vent them completely compared to the old thick tube with wider sections. Pity they don't make them like that anymore.1
Find some good used 1930's radiators and have them sand blasted, pressure tested, and painted.
3PSI gauge0
