Storage tank - recommendations
I am a home owner and I have a GSHP (ground source heat pump) system for comfort heating and cooling. It has a tank in the primary loop off the heat pump unit. The tank that was installed is probably steel and has fiberglass insulation underneath a steel jacket. During cooling season, the insulation becomes saturated with water from condensation.
I am wondering if anyone could recommend a storage tank that is insulated for chilled water, but also capable of storing hot water (less than 120 degF). The tank is probably about 30 gallons. No bladder, no coils. Has inlet and outlet and drain bungs, and a sensor well.
