Wiring boiler valve thermostat
landeal
Member Posts: 2
Cannot figure this wiring to properly wire this to a thermostat so I don't mess it up... does anyone know the proper configuration?
The RED wires connect to the end switch (micro switch) and the TT connections on the relay or aquastat. The RED wires turn the boiler on.
The YELLOW wires connect in this order: 24V transformer to thermostat to YELLOW wire thru (the motor) in valve (that closes the end switch) out of the valve to the transformer.0 -
Thank you very much0
- 125 Chimneys & Flues
