Inline Pot Feeder
cnmdesign
cnmdesign Member Posts: 103
edited December 2017 in THE MAIN WALL
Should additives be needed sometime during the life of the P/S system, what is the item called that lets you add fluids to a closed system without opening it,where can I get one or is one ever needed?. I think they are called inline chemical pot feeders. Thanks
Combat Veteran owned, Final Salute LLC on FaceBook & Twitter.
www.afinalsalute.com
    EBEBRATT-Ed Member Posts: 19,588
    Their called "shot feeders". Depending on the size of your system and the amount of chemicals to be added you could make one up out of pipe fittings if need be.
    Google: Neptune, Wessels Co or JL Wingert
    cnmdesign
  • Zman
    Zman Member Posts: 7,611
    I have heard them called both.....
    Albert Einstein
    cnmdesign
