buzzing from new controller?
larrym
Member Posts: 1
in Gas Heating
Just installed a new S8610U Honeywell Universal Controller, the system works properly but with system on but not being commanded on the controller buzzes all the time. No led's lighting. My old controller did not buzz. Any suggestions for what is going on?
My first thought would be... did everything get screwed/bolted down tight? Is this a 60 hz (power line frequency) buzz?Br. Jamie, osb
All you can do is check the wiring over and make sure it is correct. If it is it sounds like a bad module. Are you sure your ignitor is not sparking?0
- 128 Chimneys & Flues
