Leaked expansion tank
The expansion tank of our boiler had a pinhole leak last night and I patched it. I am wondering if I need to had it replaced or check the pressure or something. Thanks.
  • Ironman
    Ironman Member Posts: 7,859
    Replace it.
    Bob Boan
    kcopp
    hot_rod Member Posts: 26,604
    Also make sure it is sized correctly. If the tank is undersized it can push the diaphragm to the end and cause premature failure
  • kcopp
    kcopp Member Posts: 4,630
    The other thing I have seen is pinholes happening in tanks where the tubing in the system is of the non oxygen barrier variety. This causes premature failure of the tank.
  • MikeJ
    MikeJ Member Posts: 103
    Need to replace it of course, but how did you patch it?
