Caleffi air vents any good to replace tacos? Necessary with Spirovent
cwilliams2000
With the season coming I wanted to replace a few worn out parts. I have Taco vents on all my zones and except for maybe 2 they are all frozen or not doing much. The reviews for the Taco's seem mixed. I would like to get a high quality one that would last for some time and the Caleffi's seem good but wanted your opinion.
I have a Siprovent above my expansion tank but these ones on the zones still seem to catch some air. Or maybe they aren't need with the spirovent?
Thank you
Thank you
Can you give a little more detail. What type of emitters do you have? Where are the vents on the zones?
Caleffi is an excellent product.Bob Boan
A good central air eliminator intro is the way to go.
Use a micro bubble type to get all the air and micro bubbles out. Micro bubble removers will have some sort of mesh or media inside to grab the tiny bubbles created as the water is heated.
The device needs to be in the hottest point in the system, right at the boiler supply outlet.
At a high spot in the piping a float type auto vent or hydroscopic vent is helpful for air that may be trapped in off season.
A 3 in 1 device has addition value to remove air, dirt, and any small magnetic particles like magnetite. The mag function gives additional protection to ant ECM pumps in the system or that may be added.
Installers are amazed when they open the flush valve at the bottom the first time and see how much crud comes out, even in brand new systems.
Living the hydronic dream0
- 135 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Job Opportunities
