P/S Piping 1971 Utica model PGB100 to unscrew or not to unscrew ..that is the question
HydroNiCK
HydroNiCK Member Posts: 186
edited October 2017 in THE MAIN WALL
I have a feeling that I'm not going to be able to unscrew this nipple even if i wanted to..what say yous..? I want to p/s pump my system. My calculations call for 1"pipe However as you can see in the pics. The return tapping is 1-1/2" reduced to 3/4 and the supply is 1-1/2" with 1-1/4" reducer currently reduced to 3/4. Can I leave the tappings alone and use 1" to 1.5" reducers at the nipples? Will it be too much of a problem with my flow?
    EBEBRATT-Ed Member Posts: 19,599
    You need 1" IPS to get the correct flow for that boiler
    But If the nipples coming out of the boiler are 3/4" and are only a few inches long (say 6") and you can increase the pipe size to 1" right away you will be ok. You need to move 8 gpm
  • Paul48
    Paul48 Member Posts: 4,469
    On a boiler that age, I'd leave well enough alone.
    Ironman
  • Ironman
    Ironman Member Posts: 7,858
    edited October 2017
    Why would you want to re-pipe a 46 year old boiler? If it works, leave it alone. If you want better efficiency, then it's time for a new one. I can't see where p/s is gonna be any benefit.
    Bob Boan
