heater needed for sunroom
zepfan
Hoping to get some suggestions on an electric heater to install in a sunroom that is appx. 168 ft2, on grade, and has an eight ft. ceiling. The house is all electric, no gas or oil is available. The home owner has already said no to a mini split because the do not need, or want ac. They are only concerned about heat in the winter. The only place to mount something is above the sliding glass door that you walk through to enter the main house.That spot is appx. eight foot long x two foot high. The rest of the room is sliding glass doors on the three other exposures, so this rules out baseboard.I was hoping to install an electric fan forced heater in the five to seven kw range. The homeowners are currently heating the room with three 1500 watt space heaters. Any suggestions would be much appreciated. thanks to all.
I have never used them. I have seen them used in 1 house here in NH. Placed on the outside walls they will prob be fine. That is a hard to heat area w all that glass.0
Thanks to all for the suggestions of this product I am going to look into it0
I have used these often. They are a perfect product for your application.kcopp said:Try this approach...
http://www.radiantsystemsinc.com/"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
