thin tube (water type) radiator?
SeanBeans
Member Posts: 525
I ordered EDR by Dan but unfortunately it isn't here yet. I have a house that has identical reds and these are what they look like.. are these thin-tube (water-tube) radiators? as seen in TLAOSH?
thanks in advance!
there is a small stamp if you zoom in labeled "SD"
thanks in advance!
That looks more like the Slenderized radiator .DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Chart
how wide?0
@Dave0176 is correct. Those are small-tube or "slenderized" (Burnham's trademark) radiators. If there is any question, the section spacing of small-tube rads is 1-1/2" or 1-3/4", whereas the older large-tube ones is 2-1/2".
The ones shown in "Lost Art" are large-tube radiators.
And to make things even more interesting, American Radiator Co. made a version of the Corto tube-type rad with 2" section spacing from about 1920-1925. The chart for these is here:
https://heatinghelp.com/heating-museum/corto-radiators/
Later versions of the Corto used the standard 2-1/2" spacing.All Steamed Up, Inc.
Consulting0 -
I use the Governale charts for those radiators:
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Burnham IN3 puts out 158 sq from steam.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 982 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
