Connecting boiler to existing thermostat
Folks, I need to attach the R&W wires from my boiler into the thermostat that currently controls my SpacePak A/C, which has four wires already attached, including a R wire as shown.
That existing red wire concerns me. Do I just put the R from my boiler into the same R terminal where the existing R wire is?
DIY'er ... ripped out a perfectly good forced-air furnace and replaced it with hot water & radiators.
  • Zman
    Zman Member Posts: 7,611
    Do you have wiring diagram for the t-stat?
    You want to be careful not to combine the power from spacepac with the boiler power. You could end up with 48 volts (and associated smoke).
    Albert Einstein
  • newagedawn
    newagedawn Member Posts: 586
    to r or rc and w
    "The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
    HVACNUT Member Posts: 7,379
    edited September 2017
    Remove the jumper between R and RC.
    Put the red from your A/C to RC.
    Red from the boiler to R.
    White to W.
  • Boon
    Boon Member Posts: 261
    Zman I found the wiring diagram. I deserve a kick in the butt for not looking there first. It confirms what hvacnut says. Thanks all.
