What type of paint should I use on cast iron baseboard?
rickster05
Member Posts: 39
I'm in the process of restoring and installing some old Crane baseboard. I have used a stripper to remove almost all of the paint. I want to paint them to match my existing mop boards and am wondering what type of paint I should use? I would prefer to use a roller and brush, not spray paint.
In the past, I have had radiators sand blasted and powder coated, but not possible with these. Thanks!
Tarm Solo Plus wood boiler with 600 gal storage tank using repurposed cast iron radiators.
How can I find the link? I did use a cleaner after, so hopefully it won't off gass too bad...Tarm Solo Plus wood boiler with 600 gal storage tank using repurposed cast iron radiators.0
I've customarily used the same paints I use for walls and baseboard on my radiators -- Benjamin Moore Aqua, although other companies make paint which is just as good. Some don't, of course...
Since you have used stripper, though, even with the cleaner I would be very much inclined to use a quality primer first, such as Zinsser's Bin or the one from Benjamin Moore.Br. Jamie, osb
Question, what will the primer do regarding the stripper/cleaner?Tarm Solo Plus wood boiler with 600 gal storage tank using repurposed cast iron radiators.0
We painted our Burnham BASE-RAY. We used Benjamin Moore Satin Impervo, a paint brush, and a lot of patience.
Here's the article: https://heatinghelp.com/systems-help-center/how-do-you-paint-cast-iron-baseboard-radiators/President
HeatingHelp.com0 -
I installed 22' of new Gov-Board (trade name for Burnham Base-Ray cast iron baseboard) last month. It was factory primed.
Here's what the Install Manual recommended regarding paint...
Painting – Gov-Board and Trim are primed with a latex
(water based) paint and must be top coated with a high
grade oil or solvent based enamel to prevent rusting of
the metals immediately after installation. Primer coated
products should not be allowed to sweat as a result of
high room humidity or cold water in system. The use of
flat wall paint is not recommended since it may chip or
crack when applied to surfaces that are heated. Consult
reputable paint dealer.
I sprayed them with Rustoleum primer prior to install then painted them with regular rustoleum shoe leather brown enamel using a hot-dog roller after installation. They came out looking really nice.
They did stink for a few days afterwards, but being summertime we left all the windows open till the smell stopped (4-days or so IIRC).0
