7.5 Ton Comfortmaker replacement
Dave0176
Member Posts: 1,178
Replaced an old Carrier condenser and Evap coil. Used Comfortmaker because they are basically rebranded Carriers, I wanted to keep the evaporator size the same so I wouldn't have to make transitions. Ran a new line as the old one was not properly sized they had run a 5/8" liquid this machine called for 1/2".
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......
Yes and might I add that right around the time I was trying charge the unit it just started to completely monsoon, I barely got the tools in the truck, I was drenched my Testos got drenched too. They actually stopped working, I thought they were done but a few days later they started working again. Anyway that was a 2 hour rain delay.HVACNUT said:Nice job! Long day huh? The sun went night night for those last pics.
You can leave the copper by my garage whenever you have time.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......0
