No DHW on Buderus GB142
davidcross
davidcross Member Posts: 1
I have a GB142 working with both space heating and heating a DHW storage tank. Recently the DHW side has stopped working. At first I suspected a bad temp sensor. Then I noticed that when I turned the DHW temp control knob on the GB142 back and forth, I can hear a relay clicking. The LED under the knob does not light. This makes me think that the sensor is ok and the problem is deeper in the GB142. Any ideas?
  • Ironman
    Ironman Member Posts: 7,927
    Check the resistance of the sensor and compare it to the chart in the service manual to see if it's in range for the corresponding temp.
    Bob Boan
