Flexible steam piping
David_54
Member Posts: 16
Does anyone know of any flexible, pre-insulated piping that would be acceptable for low pressure <= 1lb steam, for residential use? I'd like something I could easily fish down an existing wall from second floor to basement.
Is the route a straight shot down?
lengths of black pipe, with couplings could work.--NBC0 -
I'd have to look it up again, but there is stuff out there. Don't think it's pre insulated and you don't want to pay for it. It would be cheaper to build a new house (roughly speaking). We bought some for a test lab that needed vibration/movement isolation to get the steam into the test chamber.
Do you have an issue with running black pipe?0 -
Fish down some urethane hose. At one pound what's the worse that can happen?0
You can use silicon hose - good for -65° to 350°F (-53.9°C to +176.6°C). Many sizes to choose from. Will, definitely, work for your operating parameters.
Optionally, connect pieces of pipe with silicon hose, clamp them, insulate (if opening is big enough) and fish through wall.
Easy to assemble/disassemble/inspect/pitch. Bonus - pipe thermal expansion is compensated.
In this case "You can have it good, fast or cheap". Pick all 3
1 -
The silicon hose solution sounds interesting. Any recommended sources for hose, fittings, etc? It's just that I can't open up the wall to easily route black iron (which would be my first choice, btw). The upper and lower walls construction and its many windows dictate the need for an alternate solution.0
