Help with edr
bigsteamedp
Member Posts: 20
Hi,
I'm hoping to get a little confirmation on what I've calculated for the EDR of this Rad. I'm thinking about 10 per section or 90 edr
Here's the specs:
3.5 wide col
6 col per sec, 9 sec, 12" sec
Overall it's 120 x 30 x 3.5
Here's the specs:
3.5 wide col
I am thinking about 125.New England SteamWorks
newenglandsteamworks.com0 -
Thanks! I think you're probably right. It throws tons of heat!0
If the sections are about 29h X 18w, then 9 sq. ft. per section.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
