Tekmar 562 wont turn on fan
Gooch
Member Posts: 62
Just installed a new Tekmar 562 and I can't get it to close the fan contact. Auto or manual doesn't work. I've tried adjusting which heat calls turn on the fan doesn't matter. I get rh1 and rh2 to close. But can't get the fan.
I would get with tech support. They are quite good and should be able to resolve this..."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
