Steam velocity
Does reduction of pipe diameter have an affect on steam velocity ? I have a few radiators that branch off the 2 inch main with 1 inch pipe . thank
Of course. For a given amount of steam, the smaller the diameter pipe will have a greater velocity. However, the smaller diameter pipe will also have more friction, so the amount of steam which can be run through a small pipe for a given pressure difference will be reduced.Br. Jamie, osb
you got three radiators on a 1'' pipe??gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
