Higher orange and yellow flames
eltin
eltin Member Posts: 43
The burner flames on the steam boiler was blue before sweeping up dust from from around the boiler. I have noticed that the flames are now higher and very bright yellow to orange. I am thinking that its due to the heavy dust that was in the area, or I could be wrong. Its been a few days now and still the same
    Jamie Hall Member Posts: 26,837
    When you were sweeping, did much dust get into the burner area? Things may have gotten somewhat gunked up in there. That flame colour suggests that the air balance is now off. You might need to get someone to clean the blower and air shutters and all and then check and adjust the burners.
  • Paul S_3
    Paul S_3 Member Posts: 1,291
    Like @Jamie Hall said.....and call a pro to perform a combustion analysis with a digital analyzer....
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
  • eltin
    It's newly poured concrete floor. I was taking down insulation from the ceiling. The floor is dusty also. Is it this that has contributed to the off balance?
  • Paul S_3
    edited December 2016
    Was some sheet rock installed? I usually see problems from the sanding of the compound .....really should not run a boiler when theres construction
    347-692-4777
    ASMHVACNYC.COM
  • eltin
    Yes I was cutting strips of sheet rock
  • Abracadabra
    Abracadabra Member Posts: 1,949
    clean the burners?
  • eltin
    I did and the flame went down a bit. Does that attribute to the high flames?
    Sorry, but the whole burner and air system needs to be cleaned and readjusted, with proper gauges...
    Paul S_3
