Thermostat
Sometimes the boiler doesn't turn on even
though the temperature is 2 Degrees under
thermostat setting (digital Honeywell) any ideas why this happens? Thanks, steam-one pipe system.
    Jamie Hall Member Posts: 27,513
    Battery thermostat? If so, are the batteries good? Then -- does the thermostat have a little indicator to say that it's calling for heat (most Honeywells do). If it's not calling for heat, then there may be a problem with the thermostat. If it is, time to check the boiler -- but what to check I cannot say without knowing a lot more about your system!
  • heatinghelpfor3
    heatinghelpfor3 Member Posts: 17
    I'll start with the battery, thanks for the advice
  • lchmb
    lchmb Member Posts: 2,997
    It could be it's not set for steam. Check the instructions and make sure it's set up properly
    LionA29
  • LionA29
    LionA29 Member Posts: 254
    @heatinghelpfor3 check your " setup" instruction page like @Ichmb suggested. Good luck
  • Koan
    Koan Member Posts: 450
    Might be set up to cycle once per hour keeping it from firing
