Utica , Dunkirk DWB SERIES CCB-150 GAS-FIRED, non condensing boiler
giorgi1969
Member Posts: 10
in Gas Heating
Looking for review .
Any help will appreciated. Quality ??? If anyone has a Utica combi please post your experience.....
I think enough people responded to your first topic, https://forum.heatinghelp.com/discussion/159706/dunkirk-dwb-series-ccb-150-gas-fired-non-condensing-boiler-for-1000sq-f-condo-chimney-vented
Asking in another forum is not likely to change the consensus that specific boiler is massively oversized for your application and that it will likely cause problems or early failure. Someone also mentioned that you may have a fresh air/combustion issue with something that large. These people know what they are talking about. If a heating contractor quoted you that equipment and is willing to stand behind their install that's all you can do. I'm just a homeowner but even I know that unit is not the best fit for the home you described.0 -
THANKS0
- 120 Geothermal
- 169 Indoor-Air Quality
