Misc 2" PolyPro
Boon
I have an assortment of 2" PolyPro fittings that I wasn't able to make use of. I can drop these in UPS or you can pick them up if you're in the DC metro area. Make an offer, my expectations are low. PM me.
1 - 18" length
1 - 36" length
1 - test port
2 - appliance adapters (2PPS-AD) without clamp
2 - elbows
5 - locking rings
1 - 2"-4" adapter connector
1 - 18" length
1 - 36" length
1 - test port
2 - elbows
5 - locking rings
DIY'er ... ripped out a perfectly good forced-air furnace and replaced it with hot water & radiators.
Boon that's a generous off about the analyzer. Did you have to do the combustion air or only the flue? I didn't put in a test port on the fresh air, so I might need to add one, maybe i would grab those 90s from you as well in case i find my outside terminations are short cycling or picking up drafts or rain.
I wanted to ask about the analyzer, do you think we will have to analyze more than once?0 -
Sorry. I should've updated this post... all this stuff is gone.
I will likely need the analyzer to make another adjustment this week and after that I expect I'd only need it for maintenance. PM me if you'll need it. No need for a test port on the fresh air side; I don't know of anything to test on the fresh air side.DIY'er ... ripped out a perfectly good forced-air furnace and replaced it with hot water & radiators.0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
