Asking for quick help...pex clamping options
warno
warno Member Posts: 229
edited September 2016 in THE MAIN WALL
Is there any other way to attach pex crimp fittings to the tubing other then the crimp rings or the clamps? I didn't plan well on 2 of my fittings and now I can't get my crimp tool into the area to crimp the ring. I can't open the handles enough to get around the pex. So I'm wondering if there's any other way to pull the pex tight enough to its barb to seal it up?
I have a band clamp tool available to me that we use on our air lines at work. Would that work? I have the room to use it. It uses the attached picture band and holder.
Any help would be great. Thank you.
  • Solid_Fuel_Man
    Use chinch rings if you can't get the crush ring tool in the space.
    Taylor
    kcopp
  • Ironman
    Ironman Member Posts: 7,927
    You don't wanna use anything other than an approved method. Too little squeeze and it leaks; too much squeeze and it leaks.
    There are pinch type clamps available, but I don't recommend using them on hydronic lines; I'm seen them break on more than one occasion.
    The big box store has a crimping block the you pinch with vise grips for about $30. Never tried it, but it should work.
    There are also two expansion methods for type A pex, but the tools are mucho dinero.
    Do you have an angled or straight crimp tool?
    Bob Boan
    Solid_Fuel_Man
  • warno
    I'll have to look around the Internet for something similar. My line is 1". I was hoping to get away with the band clamp idea but was leery of it. I have another idea which requires welding but that will make the threaded portion of this area impossible to tighten if it leaks.
    Thanks for the help guys. I'll check into those other tools. If I can't get it, I'll weld it.
    hot_rod Member Posts: 27,840
    In the same pinch one day I cut one handle off the crimp tool. Put the tool on the ring and used a vise grip as a handle. I converted that tool to a removable handle version, still have it 20 years later.
    Here is another
    1" version with steel handles.
    Solid_Fuel_Man
  • Ironman
    Some supply houses, such as Fergusons, rent ProPress tools. They should have a 1" pex head to go on the ProPress.
    Bob Boan
    delta T
  • warno
    I think I have another route I can go. I didn't think of it until this morning while looking at it again. I can add in a threaded coupling and use a 12" long pipe nipple to extend out where I can weld onto my other part. That way I can still break it down if need be.
    Thanks everyone for the quick responses. I'll keep them in mind if I ever run into this again.
