return piping under-ground
Snowmelt
Member Posts: 1,428
is there anything wrong with connecting the return like this ?
the pipe on the right is below the pipe on left, the pipe on right is a return that goes under ground ( there is a door that it goes under). the pipe on the left is connected to the hart ford loop. the pipe coming down on the left is the second return in the system which is a no brainier .
thanks ezzt, i wasn't sure, in my head I was saying to myself that its udder the water line anyways so its going to fill with water no mater what0
Exactly. The key thing is that the mud and rust needs to be flushed out periodically0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
