return piping under-ground
Snowmelt
Member Posts: 1,415
is there anything wrong with connecting the return like this ?
the pipe on the right is below the pipe on left, the pipe on right is a return that goes under ground ( there is a door that it goes under). the pipe on the left is connected to the hart ford loop. the pipe coming down on the left is the second return in the system which is a no brainier .
thanks ezzt, i wasn't sure, in my head I was saying to myself that its udder the water line anyways so its going to fill with water no mater what0
Exactly. The key thing is that the mud and rust needs to be flushed out periodically0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
