Repiping a steam boiler
excellent looking job. Should purr like a kitten now
gwgillplumbingandheating.com
Isn't there some down side (venturi effect) to bushing the bull of a header tee?
And please post the numbers from a combustion test before the draft hood so we know what's going on with the boiler. Sustained low fire makes me nervous when untested.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes2 -
Great workmanship! My shoulders hurt just looking at that.Steve Minnich0
Hi JohnNY- i can't vouch for the other guys, but i've never experienced any adverse effects from bushing a header tee's take off.JohnNY said:Isn't there some down side (venturi effect) to bushing the bull of a header tee?
And please post the numbers from a combustion test before the draft hood so we know what's going on with the boiler. Sustained low fire makes me nervous when untested.gwgillplumbingandheating.com
How would you know?
I mean it's been said many times in this forum and in seminars...there's that slide Dan shows of a steam boiler illustration and he states there are several things wrong with the piping. One is the header tee being reduced at the bull.
Personally, I'd like to know there is no appreciable benefit to using a full-size tee and then a nipple and reducing coupling but that's not what I've been led to believe.
I don't think there is a metering device to test for carry-over moisture in the header but if there is, I want one.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes1 -
I feel it depends on how many mains are pulling from the header.
If only one, it could be a big problem but if you have 2, 3 or 4 mains pulling from the header and their inside area is equal to, or larger than the header when bushed down I don't see why bushing it down would matter as long as the steam velocity is low enough.
For example, two 2" mains pulling from a 3" header shouldn't have an issue where one 2" main pulling from a 3" header may.
I don't really know, just trying to picture it in my head.
Beautiful work. More like Pipe Porn0
- 167 Indoor-Air Quality
