No hot water please help
have Weil McLain WTGO-3 tankless coil with a Carlin EZ-1 burner and a Fuelsmart hydrostat 3200 plus, for some reason I have no hot water in the house can you help me?
  • kcopp
    kcopp Member Posts: 4,630
    is there power to the boiler? What is working? Tell us more.?
  • Tomday88
    Tomday88 Member Posts: 2
    It has power, and the display on the hydrostat says 89, if I adjust the low temperature limit the boiler will kick on and stay on but I still won't get hot water I let it run for just under an hour but no change to anything I'm guessing it shouldn't stay running like that ether :( I just don't know much about these things.
  • STEVEusaPA
    It's either a loose wire, or it's broke. Is it sending power to the burner? Can't really tell you more than that without putting my hands/meter on it.
    Jamie Hall Member Posts: 26,837
    Does the water get hot when you force the boiler to run by adjusting the low temperature limit? If so, then it is -- as @STEVEusaPA said -- a loose wire or a problem in the hot water sensing -- which should be keeping the boiler warm all the time, to make the hot water.
    Steamhead Member Posts: 18,203
    Call a pro.
    Consulting
