Unistrut Clamps
Harvey Ramer
Harvey Ramer Member Posts: 2,281
Where are you guys buying the rubber or plastic lined unistrut Clamps for CTS size?
  • Paul S_3
    Paul S_3 Member Posts: 1,291
    are you refering to cushion clamps for uni strut....i buy boxes of 50 from supplyhouse.com.....and my plumbing supply stocks them too for me....i also buy cushion split rings
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
  • SWEI
    SWEI Member Posts: 7,348
    Ferguson stocks them in their DC's (ProFlo branded, less expensive than the big names.)
    hot_rod Member Posts: 26,594
    Johnstone Supply, probably SupplyHouse online.
    The refrigeration suppliers have them down to 1/4 cts size if you want to mount remote air vent lines :)
  • Harvey Ramer
    Thanks guys!
    @hot rod
    Yes indeed! Those remote air vent lines are important with you have air vents on top of those big storage tanks. Every vent leaks sooner or later.
  • Solid_Fuel_Man
    I buy from FW Webb as well. We use them extensively on all refrigeration, they are listed by tube OD, so 3/4 cts is referred to as 7/8 cushion strut clamp 1/2 cts is 5/8 cushion clamp etc.
    TS
  • Ironman
    Ironman Member Posts: 7,858
    Harvey, is there an Aireco or united Refrigeration near you?
    Bob Boan
    Thanks guys!
    @hot rod
    Air vents above boilers can be a big problem also. They tend to leak down into the most expensive components, control boards, fan motor controls, etc. That is where a vent tube has some real value.
  • Getting back to strut clamps, I'd like to see a good way to insulate them. We just stop the insulation at the unistrut.
  • Harvey Ramer
    I have a United Refrigeration close by. It's a satellite branch. Never seen them on the shelf but i guess ill have to ask them. Supplyhouse.com I guess would be an option as well.
  • Ironman
    RE Michel can get for you if they're not on there self.
    Aireco in Winchester has them too. Probably about an hour from you?
    Bob Boan
    Harvey Ramer
  • Ironman
    If you go with a bigger clamp and wrap tape around where the clamp goes, just let the closed cell pass through it. Obviously, it won't grip it as tightly, but usually that's not an issue.
    Bob Boan
  • Harvey Ramer
    Winchester is a little bit far to go for clamps.
    @Alan (California Radiant) Forbes
    I have used these before http://s3.supplyhouse.com/images/products/large/hr-724112-1.jpg
    EBEBRATT-Ed Member Posts: 19,591
    Someone makes insulated strut clamps. I saw them advertised but don't remember where. Will do a little searching
    google Cooper Industries they make strut clamps with insulation inserts for 1/2 or 3/4 or 1" wall insulation
