i see at least
Paul S_3
Paul S_3 Member Posts: 1,291
one of these a week....this company
by me continues to install these and people pay him....
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    Wow.
    Steve Minnich
    rick in Alaska
  • warno
    warno Member Posts: 229
    I am by no means a plumber but I could a better job then that. Good lord that's bad.
  • lchmb
    lchmb Member Posts: 2,997
    ok...no words can describe that...
  • Paul S_3
    edited June 2016
    Thats Brooklyn for ya!!...Lol....I dont if you guys recall i posted a job where i ran all exposed copper propress Viega piping in a brownstone about a few months ago to correct a job that wouldnt work below 50F .....I lost the job to this contractor. This is what i have to deal with....I am beginning to believe by me if your not on Heatinghelp.com your not a good contractor. Its so sad.
    347-692-4777
    ASMHVACNYC.COM
  • warno
    edited June 2016
    I wondered that to? It looks to be tied to the drain. :-/
    What's up with the rubber coupler holding that clean out in the pvc wye? Run out of glue?
    Also the guy should invest in a level. BAD!
  • Paul S_3
    @Hatterasguy .....pump is on return of a 56 ft 1/2" fin tube baseboard zone...more than double what is allowable for a standard 20F delta T......the supply of the loop is through the hot water outlet of the heater.....the feed is through the cold water inlet of the tank VIA filltrol....
    347-692-4777
    ASMHVACNYC.COM
  • rick in Alaska
    rick in Alaska Member Posts: 1,513
    Love the sewer line in front of the firebox.
    And the workmanship.........
    Rick
  • "They walk among us..............." And you know what? They will always be there.
  • JUGHNE
    JUGHNE Member Posts: 11,513
    He must not be the tinner as the RA drop looks pretty good.
  • rick in Alaska
    Makes you wonder where the rest of the gas line is going after the shutoff valve. Seems to split off after the valve and go through the wall.
    Rick
  • Abracadabra
    Abracadabra Member Posts: 1,949
    Do those solder joints have enough solder? ;)
  • JUGHNE
    That draft hood on the WH looks mismatched, as if it came off the previous tank.
    But what part of it didn't work.....I assume that is why you were called.
  • Paul S_3
    i guess its working...i was there installing a furnace ,coil and condenser
    347-692-4777
    ASMHVACNYC.COM
  • JUGHNE
    That explains the good looking duct work! It didn't seem possible the plumbing set up came out of the same worktruck.
  • AMservices
    AMservices Member Posts: 611
    I didn't know "whirlpool" made a combi boiler
    Hatterasguy4Johnpipe
