i see at least
Paul S_3
Member Posts: 1,261
one of these a week....this company
by me continues to install these and people pay him....
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
I am by no means a plumber but I could a better job then that. Good lord that's bad.0
ok...no words can describe that...0
Thats Brooklyn for ya!!...Lol....I dont if you guys recall i posted a job where i ran all exposed copper propress Viega piping in a brownstone about a few months ago to correct a job that wouldnt work below 50F .....I lost the job to this contractor. This is what i have to deal with....I am beginning to believe by me if your not on Heatinghelp.com your not a good contractor. Its so sad.ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
I wondered that to? It looks to be tied to the drain. :-/
What's up with the rubber coupler holding that clean out in the pvc wye? Run out of glue?
Also the guy should invest in a level. BAD!0 -
@Hatterasguy .....pump is on return of a 56 ft 1/2" fin tube baseboard zone...more than double what is allowable for a standard 20F delta T......the supply of the loop is through the hot water outlet of the heater.....the feed is through the cold water inlet of the tank VIA filltrol....ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Love the sewer line in front of the firebox.
And the workmanship.........
Rick0 -
"They walk among us..............." And you know what? They will always be there.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
He must not be the tinner as the RA drop looks pretty good.0
Makes you wonder where the rest of the gas line is going after the shutoff valve. Seems to split off after the valve and go through the wall.
Rick0 -
Do those solder joints have enough solder?0
That draft hood on the WH looks mismatched, as if it came off the previous tank.
But what part of it didn't work.....I assume that is why you were called.0 -
i guess its working...i was there installing a furnace ,coil and condenserASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
That explains the good looking duct work! It didn't seem possible the plumbing set up came out of the same worktruck.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
