Another Megasteam
RJMCTAFO
RJMCTAFO Member Posts: 113
I always forget to take pics of the old system. It was a 4 section American Standard double door. The only main vent was a no name 1/8" radiator vent. EDR came in at 214.
Customer was on a very tight budget so we did the best we could within that constraint.
MST-288 and 2 No 1 vents. We plan on adding additional venting next year at the tune up.
I have no clue how anyone can see water like that and not endorse skimming/cleaning new boilers.
Paul S_3SWEIjonny88
  • Paul S_3
    Paul S_3 Member Posts: 1,294
    Nice install @RJMCTAFO
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
    RJMCTAFO
  • BobC
    BobC Member Posts: 5,566
    That's what I'd have in my basement now if Burnham wasn't so dead against a gas gun in their wet based boilers.
    Bob
    3PSI gauge
  • RJMCTAFO
    Yeah it is interesting that they take such a hardline stance on the conversion burners. One can only assume that efficiency with a conversion burner would be light years ahead of an atmospheric.
    I have a customer that needs a new steam boiler replaced. She filled out an application for an energy loan. They will finance a gas fired boiler that is 82% but not a Megasteam oil boiler that is 86%.
    GreenGene
  • GreenGene
    GreenGene Member Posts: 290
    Agreed, when I taught at Porter&Chester we had a Carlin EZ Gas burner and we'd experiment putting it in a variety of equipment, good experience for the students to do sizing, we'd make up a piping and sizing the orifice scenario like you would doing a gas conversion.
    It always ran great, especially the steam, we had a WeilMcLain gold steam boiler, it ran smoother building and keeping a head of steam probably due to the lower flame temps, I think that's their beef, but never saw any issues related to that. The Carlin EZ gas is a great burner IMHO.
  • SWEI
    SWEI Member Posts: 7,342
    The difference in flame temps is less than 7 percent. Their beef appears to lack a rational basis.
    Steamhead Member Posts: 18,497
    edited May 2016
    As energy efficiency standards get higher, they'll have to go the MegaSteam/power burner route. The Independence is probably maxed out already, efficiency-wise.
    Nice looking install- that's a MST-289, right?
    Consulting
    SWEI
  • RJMCTAFO
    Yes Sir, a 288. A compliment from you means I must be doing something correct. Thanks
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,547
    Nice, clean job brother. Mad Dog
  • ChrisJ
    ChrisJ Member Posts: 17,383
    We were able to get 84 or 85% out of my EG-40, just not with the drafthood blocked.
    I wonder if there's a chance we'll start seeing pin type boilers shipping with barometric dampers running richer in the future.
    Maybe?
  • RJMCTAFO
    I can not remember the specific numbers but I know that after dialing in draft my stack temp was 370* steady state. In the 86% combustion efficiency.
  • ChrisJ
    Here's my EG-40's results with the barometric damper, 4" manifold pressure and a brick baffle.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,591
    99F ambient?
  • ChrisJ
    99F ambient?
    Not sure on that one, my basement runs warm especially if it's warmer outside which it was, but more like 75-80. I assume the analyzer was just near the boiler.
  • Robert O'Brien
    The 99F ambient is clearly an error. It skews the entire result by lowering the net stack temperature and thereby raising the efficiency.
    My point
    Hatterasguy
  • ChrisJ
    My point
    Ok.
    So skew it properly, assume 80F ambient.
  • SWEI
    edited May 2016
    There's a reason we put the T2 probe in the air inlet pipe on sealed combustion appliances. CA efficiency numbers are not reliable regardless.
