Any Water Stopper Tools for Soldering for sale?
JUGHNE
Member Posts: 11,591
With the increase of compression copper fittings, does anyone have a Stopper Tool they want to sell?
I have noticed comments about not using a torch more and more frequently. Would consider a full 1/2 to 2" set.
Might have a project coming where this would be handy.
I've heard of using bread.
What's a water stopper tool? The pipe freezer?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Expandable internal pipe plug connected to and operated by a 12-16" rod. Cut pipe, insert plug into pipe a few inches, tighten plug with wrench. Slip ball valve or straight fitting over end of pipe and solder a dry fitting.
There are various clams of how much pressure they will hold. I would just need them for the low dripping/flow.
1 1/2" copper takes a lot of bread and it is potable water in hospital and nursing home.0 -
The Jet Swet is a handy tool for small sizes. I think a plumber out in Vegas invented this.
Hodes Supply once had small mineral oil capsules. It worked similar to bread, but less mess
Slide them in the pipe upstream from the repair, then heat right at the
to dissolve it.
Or a freeze cuff.Bob "hot rod" Rohr
Living the hydronic dream1 -
Thanks, Hot Rod. I have shopped around before the initial posting and thought someone might have a set gathering dust on the top shelf as most are embracing the Pro-Press etc.
I might only use them 10 to 12 times and then retire the torch and it's operator. Should have brought them 30 years ago. These were luxuries that I assumed the shoestring budget would never tolerate. But thinking of the time wasted chasing water or trying to boil water while soldering, then pressurize to discover a leak and start over again. The ROI would have panned out ........but when you are young and dumb....you don't need no stinking sissy tools like that
If I were to be starting again I would embrace the new methods of the time and go for the Pro Press type of connections.
I don't even have any pex tools or materials. First crimps I made were made on my own replacement infloor heating manifold, that was with a borrowed tool.
I plan to continue working until I run out of grandkids for helpers. They are all determined to be collage grads, so I will help prepare them to work the trades after they graduate with a BA. This may keep them out of the fast food industry.
1
- 125 Chimneys & Flues
