Plugged Tankless Coil
Rich_L
Member Posts: 84
I have two Ruud tankless domestic water heater in a building I just inherited to take care of. The two units are piped in parallel. I've found one of the units to have a completely plugged coil. I get absolutely no flow, even with city pressure against it. I've tried pumping cleaning solution through it, from both directions, but with no flow I can't get anywhere. Can this unit be saved? So far I've tried DHW Tankless cleaner and ice machine cleaner. I've been trying to get flow with cleaning solution for over a week now. Thanks
Remove the heat exchanger and soak in vinagar or heavier chemical for a few days?0
The HX is pretty thin in most of those units. Instead of going through all this "cleaning" I would just replace the HX.
Then find out why it did that and take action so it does not happen again.
They do make siliphos filters that allow the calcium to not stick to the piping.
http://www.aquapurefilters.com/store/product/200106.200095/ap430ss.html1 -
@kcopp has an excellent point. If it's that badly plugged, the odds of its leaking when you get the scale out of it are close to 100%.Br. Jamie, osb
Thanks for the responses. I didn't know if possibly anyone else had such experiences with these units. I believe what led to this is simply lack of attention/ maintenance. When I asked what kind of schedule they had for descaling their tankless water heaters I was met with a puzzled glare... This unit is almost six years old and has never been de-scaled! Thanks again0
Thinking past your fixed solution ....Is it piped reverse return ?
