Steam boiler repipe in Jersey City NJ
EzzyT
EzzyT Member Posts: 1,379
We repiped this boiler with a 4" drop header and the hydronic loop piping going to the indirect tank as a preheated tank for the regular hot water heater. Indirect tank started to leak after we repiped it properly. The only thing I could come up with that prevented it from leaking before or masked the leak was all the mud and dirt sitting at the bottom of tank and once we drained it and repiped it that exposed the leak. We ended up ripping out the indirect tank and the old water water heater and upgraded the water heater from a 40 gallon to a 75 gallon with a mixing valve.
The hydronic loop piping is staying for the future baseboard heat that's going into the basement.
E-Travis Mechanical LLC
Etravismechanical@gmail.com
201-887-8856
LionA29aircooled81
