1895 house steam repipe
jonny88
Member Posts: 1,139
Customer was having major uneven heating problems.We disconnected one boiler serving west wing and put complete house on main boiler ECR 299.Added vents throughout house and on mains .Boiler is running of tekmar control and so far customer is delighted with upgrade.King valves were installed to clean out boiler.Big thanks to @Hatterasguy for his invaluable input and suggestions.
1
Nice work johnny...i love the 279 & height and drop of the header ....there's some nice dry steam thereASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Thanks guys@EzzyT you guys are setting the bar high.0
Thanks @Hatterasguy .Homeowner is really appreciative for your advice and suggestions.Foyer is real comfortable.Again many thanks.0
How much of a pickup factor did this system end up with?
I was hoping you would share with the class......Hatterasguy said:Come on now............you can calculate that yourself!!!
So the numbers are right there, in the open.
Was it less than 33%?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
How's the other job with the smaller boiler doing? That one had what, 10%?Hatterasguy said:Well OK.........
794 EDR with 299K input @80%:
25.5%
You are welcome to tell certain people that it heats the building just fine.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
This is why plumbers like engineers and designers0
Very nice John, you made a junky side outlet boiler work just fine.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
