007 circulator pump question.
oreo123
Member Posts: 70
in Gas Heating
When they get older do they slow down? ( I know I slow down as I get older but that is for a whole different board.) I have a boiler with 2 zones, one is to an indirect. Second zone I suspect is not getting enough water through it for baseboard loops. Boiler is in basement and the loops are on the second floor. Pump is ~ 14 years old. I can hear it twirling with a screwdriver to my ear. Its pumping away. I suspect either the pump or the flow check. I do not hear any rushing ocean sound in the baseboard loops so I am guessing that there is not much if any air in there.
In the 20 years with this apartment never had any call about low heat so I am guessing there is enough slant fin (will add up the linear feet tomorrow, get btus, and figure room heat load). Boiler cycles on and off at high limit. Priority is to stainless indirect.
This is in Boston area, its very cold past 24 hours. Everyone is running in circles with freezeups.
thanks. I have the infrared hand held gun. and I have a pipe thermocouple & meter.
The more I think about this I suspect the flow check. The boiler next door I had an issue where a flow check was open and heat was going into that apartment when it was making domestic hot water in the summer. Upon opening it up I found a piece of cardboard that was left in there by the installers. It wedged it open.
- 125 Chimneys & Flues
- 19 Recall Announcements
