Converting from steam to hot water heat
2»
  • hboogz
    hboogz Member Posts: 113
    @Charlie from wmass If I use a pipe how would that technically be configured ?
    Find a tee on the main, branch off of it, run your new section of pipe, then drop to below water line and tie into wet return. Drill and Tap vent hole in the section where i want the pipe to act as a radiator ?
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    How much heat do you need?
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • hboogz
    As an example i would say to heat an open space of say 600sq ft .
  • ChrisJ
    ChrisJ Member Posts: 17,070
    edited December 2016
    And what's the heatloss of that 600sqft?
    If there's no exterior walls and the ceiling is below a conditioned space it could in theory be close to 0 while if all four walls are exterior and the ceiling is exterior it could be quite high depending on wall construction, insulation etc.
  • hboogz
    @ChrisJ In my application, i would consider it in a finished basement space that has, what i would imagine is the basic R15 pink fiberglass batts on a masonry house. 3 small windows. nothing crazy.
  • SWEI
    SWEI Member Posts: 7,348
    All kinds of options there. A run of pipe (perhaps 2-3 in parallel) spanning the length of the space with reflective insulation above could work wonders.
  • hboogz
    Gotcha. Am I drilling and tapping for a vent ?
    For one pipe systems yes. For 2 pipe no. Get a trap then.
    cell # 413-841-6726
