Wanted: a hot shower
Skindel
Member Posts: 14
I use steam heat and the only way to a get a realiable, hot shower is to turn the heat on for a few minutes, so my boiler turns on. Otherwise, the water is lukewarm at best. In the winter, it's not a huge deal, but I prefer not running the heat before showering in the summer. Is this connected/standard to using steam heat and how the boiler opperates or is this just my system?
Have you checked the setting on the aquastat that controls the hot water temperature? It's also possible the hot water coil has become limed up which makes it less efficient.
As to not wanting to run the steam boiler in non heating months you could install an electric hot water heater after the coil in the boiler and rely on it alone in non heating months and only sporadically during the heating season. If you had natural gas a gas hot water heater would be cheaper to run.
3PSI gauge0 -
Is there even an aquastat? One has to wonder...
What is the fuel for your boiler? Oil or LP or natural gas? Any one of the three can also power a stand alone water heater, which could be more economical.Br. Jamie, osb
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 44 Industry Classes
- 48 Job Opportunities
