Removed feed pump, water line now high.
kmh5147
Member Posts: 20
Just like the title says, I just removed my boiler feed pump and piped a proper Hartford. I now notice the water line is running 1/2 inch above the recommended. I have a 578 weilmclain, and the manual states the water level should be 32 1/4. Do you see this as being a major issue? The system is silent and I'm running at or below 0 oz (vacuum pump, story for a different day).
Thanks!
Thanks!
No. Shouldn't be a problem. WeilMcClains are pretty tolerant of variations, so long as you stay within the gauge glass!.Br. Jamie, osb
- 62 Biomass
- 114 Geothermal
