leaking indirect
I have a customer with a boiler and indirect installed in 2013. The first indirect lasted 4 months before leaking, and the second lasted 16 months. Anyone know of a good reason that this happened. Electrolysis was my thought, but the house appears to have a good ground. However there is no ground jumper across the water meter.
  • jonny88
    jonny88 Posts: 1,139
    What brand.Expansion tank installed?
  • Megastor 40. No expansion tank needed.
  • ChrisJ
    ChrisJ Posts: 17,642
    What's leaking? The tank or the coil?
  • jonny88
    I mentioned exp tank because if there is a backflow on domestic water most manufacturers require a domestic expansion tank.
  • SWEI
    SWEI Posts: 7,342
    Do you know the pH and chloride levels of the water? Is it well water?
    hot_rod Posts: 28,190
    It can be messy, but stripping away the foam insulation is the best way to find the leak. Usually it is at one of the welds on the seams or around the threaded connection weld-let.
    Water quality is always suspect with stainless tanks that fail early and often. Local supply housed generally know which tanks last in their area.
    All things considered glass lined tanks seem to handle aggressive water best, keep them below 160F for a good long life.
  • jonny88
    I did just this on a 2yr old indirect a while back.Indirect was made by one of the more reputable companies and we discovered it was a weld on the seem.Company did replace unit in fairness though.
  • unclejohn
    unclejohn Posts: 1,833
    Tringle Tube smart tanks have a life time warranty.
