Loch in a shop
Harvey Ramer
Harvey Ramer Member Posts: 2,290
Real-estate comes at a premium.
#wastenospace
jonny88Steve MinnichSWEIRobert O'BrienIronman
  • NYplumber
    NYplumber Member Posts: 503
    Very nice work. Keep posting these jobs.
    :NYplumber:
    Harvey Ramer
    hot_rod Member Posts: 27,830
    Nothing wrong with that, keeps it out of harms way.
    I like how you have it all the way up on the concrete, Ill bet it runs nice and quiet.
    Good for you on the venting material choice also.
    Picture perfect install, nice work!
    Harvey Ramer
  • bmwpowere36m3
    bmwpowere36m3 Member Posts: 512
    Nice and clean… man, if more installs looked like that!
    Harvey Ramer
  • ChrisJ
    ChrisJ Member Posts: 17,519
    Where does the condensate pump pump to?
    Just curious as I don't see the hose anywhere.
  • Rich_49
    Rich_49 Member Posts: 2,783
    Nice work as always Harvey .
    You didn't get what you didn't pay for and it will never be what you thought it would .
    732-751-1560
    Rich McGrath 732-581-3833
    Harvey Ramer
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,595
    Very nice!!
    Harvey Ramer
  • Harvey Ramer
    If you look on the upper left of the picture you can see a 3/4" pvc pipe exiting the wall @ a 45° angle. That's where the condensate is going. Designed to prevent any freezing or ice jams.
    There's no sanitary drain in the building.
    @hot rod It is very quiet. You can hear it at full fire but when it modulates down you hardly can tell it's running.
    ChrisJ
  • EzzyT
    EzzyT Member Posts: 1,380
    Beautiful job. How do like those mega-press fittings?
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
  • Harvey Ramer
    I like mega press. They sure come in handy. I always use a mixture of regular blk fittings and nipples and mega press keeps me from having to thread any pipe.
  • 347
    347 Member Posts: 151
    Harvey,
    Its a very nice looking job. You said their is no sanitary drain in the building, where did you dump the condensate? I bidding a similar job and there is on drain to get rid of the condensate.
    thanks
    Harvey Ramer
  • Tom_133
    Tom_133 Member Posts: 988
    Harvey, Great job looks good! One question about the 45 degree angle, I have always wanted to do that but have always been too scared that it would freeze, have you had any freeze ups?
    I am in Central Vermont so it gets stupid cold for weeks at a time (not this year though so far) and I would pipe in a wye to overflow so the boiler wouldn't shut down but the amount of condensate these boilers can produce scares me a bit.
    Tom
    Tom
    Montpelier Vt
    Harvey Ramer
  • Harvey Ramer
    Tom
    I haven't had any problems.
    I wouldn't do it piped gravity drain direct from the boiler though. That's just asking for trouble. The way this works is you get a whole slug of warm condensate whenever the pump runs. It can quickly and completely drain from the 45° pvc pipe to well inside the heated envelope. I try to make sure that it drains back far enough so cold air ingress through the pipe won't cause freezing. Also pipe everything with tight fittings to preserve weather-tight integrity.
  • Robert O'Connor_12
    Robert O'Connor_12 Member Posts: 728
    nice looking job
    Harvey Ramer
