WHY WOULD THERE BE A STEAM PIPING BLOWING OUTSIDE
PaulStraface_2
Member Posts: 5
A 2" STEAM PIPE RAN FROM MAIN IN BASEMENT THREW ATTIC AND BLOWS STEAM OFF OUTSIDE.
ANYONE SEE THIS BEFORE??
Possibly a vent line routed outside rather than venting off in the basement.
Need more information for better answer; type of system and pictures of near boiler piping would help a lot.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
My bet is that it isn't a steam pipe, but the vent from the dry return(s). Not that uncommon in some of the vapour systems, and works very well. Provided, of course, that the rest of the system is working properly! Very low pressure. Traps or orifices all good. That sort of thing...Br. Jamie, osb
In other words, steam shouldn't come out of the pipe correct?Jamie Hall said:My bet is that it isn't a steam pipe, but the vent from the dry return(s). Not that uncommon in some of the vapour systems, and works very well. Provided, of course, that the rest of the system is working properly! Very low pressure. Traps or orifices all good. That sort of thing...
Keep in mind that when venting, the air will be quite saturated, so what you are seeing may be the saturated air condensing due to the contact with colder air, and not really steam , but condensing vapor.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
Does that pipe look as old as the rest of the system?
There were some early 2 pipe systems that utilized the masonary chimney to assist in drawing the air out of the dry returns. Do you still have a brick chimney or has it been replaced by a "B" vent (if gas).
However I can't imagine someone recently (20-30 years)installing a new vent and adding that pipe up to the attic.
If we could see where in the basement it is connected then the reason might be figured out.
And if it was venting humid air in cold weather it could look like your clothes dryer vent does. IMHO1
- 120 Geothermal
- 394 Solar
