Electric vs Hydronic floor heating in bathrooms
aschwa
Do hydronic radiant floors provide as much comfort as electric radiant floors in bathrooms?
I'm imagining spring/summer/fall days when we'd want to have the electric radiant floors installed on a timer to warm up in the mornings. Do hydronic floors work as well for ~60-minutes per day of desired warm floors?
I'm wondering whether the slower response time of hydronic causes problems if we want warm floors for as short period of time.
A BTU is a BTU, no matter whether it is delivered with hot water in a pipe or electrons in a wire. The response time and comfort levels will depend entirely on how the heat delivered to the floor is controlled.Br. Jamie, osb
Response time is more about the method of installation. Also finished surface detail.
With electric radiant wires are embedded in the thin set for the tile so the wires are close to the surface. This can also be the case with hydronic radiant. IF the only source of heat being radiant is in those areas by all means electric would fair better.except for operating costs at least in my area.0 -
Like Gordy stated, with electric the surface temperature will be more consistent as the wire or mat has a tighter spacing than tubes and is typically right below the tile.
One of my favorite is the weave products like HeatWeave or SunTouch, very easy to install and custom size.
Be sure to add a sleeve for a floor sensor. Don't embed the sensor in the mudset, someday it will need to be replaced.
Combined with an air/ floor stat and setback function, electric radiant has some nice benefits.Bob "hot rod" Rohr
Living the hydronic dream1
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
