Homart automatic gas heat 600
gezgas
Member Posts: 1
in Gas Heating
Hi.
His is a old system. But works well. The pilot is on. The thermostat is good.
Naw the heat is not working. Can I get any advice. Please.
Is the circuit breaker tripped?
Do you have a switch on the stairway that is off?
What is the Make and Model of the gas valve?
Do you have 24 volts to the gas valve?
Is the pilot operated with a thermocouple?0
- 128 Chimneys & Flues
