Replacement Zone valve head
Le John
Le John Member Posts: 250
The cover on the zone valve identifies it as a
White Rodgers but I think it's a Honeywell. Anyway to confirm?
  • rick in Alaska
    rick in Alaska Member Posts: 1,524
    It looks like a Honeywell and the one next to it is a Honeywell, so I would say it is a Honeywell.
    Rick
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    What are the numbers on the White Rodgers cover? There is a WR head that looks like that.
  • Le John
    Hi Tim here is a better picture of the zone valve head and the
    White Rodgers Cover.
  • billtwocase
    billtwocase Member Posts: 2,384
    Replace just the 24 volt motor for a fraction of the cost
  • Tim McElwain
    That is a White Rodgers ZV 13A03-112 and it is no longer available in the White Rodgers cross reference. As was suggested you may be able to just replace the synchronous low voltage low amperage motor. If not replace the entire valve.
