boiler needs new chamber kit
eja7
eja7 Member Posts: 3
We have an old boiler and recently had the oil company come for their annual tune-up. They told us that the boiler needs a new chamber kit--but that it is no longer made, and therefore cannot be replaced. We are assuming that they are next to tell us that our only option is a new boiler. We were wondering if we have any other options. Thank you.
  • eja7
    Blue Ray BY-75/100
  • SWEI
    SWEI Member Posts: 7,342
    If (and that's a big if) the boiler is otherwise in good shape, what's wrong with a wet blanket kit?
  • Bob Bona_4
    Bob Bona_4 Member Posts: 2,080
    It's a Blue Ray steel boiler. Stick a fork in it
    Robert O'BrienZman
  • Marz
    Marz Member Posts: 90
    I agree with Bob. Out of 6000 customers there's one left here. Really not worth putting any money into it. Rare unit.
    Bob Bona_4Robert O'Brien
    Steamhead Member Posts: 18,710
    In this case, I agree. The Blueray was way ahead of its time and suffered as a result. You got a lot more life out of that one than most people did.
    A good cast-iron three-pass boiler will run as efficiently as the Blueray was supposed to. I'm assuming you don't have natural gas available?
    Consulting
  • eja7
    Thank you so much for all your help. We will get some estimates on our different options.
  • ww
    ww Member Posts: 320
    why don't you figure on what the nozzle size is and look at various charts which tell you the acceptable size of the chamber. look at the degrees on the nozzle and fix the chamber if you can using firebricks and maybe some high heat mortar or cement?
    they usually tell you making chamber a bit bigger won't be a problem. once you figure on that you can construct chamber using angles and less corners.
    all this providing you have the same type of chamber that allows you to do this. Usually alternatives of buying new boiler is given since parts aren't available..sometimes you can fix things yourself..sometimes you can't..it depends on what you want to spend and how much you have to spend.
  • billtwocase
    billtwocase Member Posts: 2,384
    As long as it doesn't have the Carlin/Blue Ray burner, and money is an issue, it can be repaired. Some Blue Ray labeled boilers were S-Series boilers, and not Scotch Marine
  • billtwocase
    Those Blur Ray horizontal boilers were also wet base. They had a target wall and cover on the rear similar to an EK
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,290
    I've used Lynn chamber kits before for old boilers. The have custom kits that you can cut to fit.
