What is this?
Matthias
Member Posts: 38
That looks like a TRANE Direct Return Trap for a two-pipe steam system. It was used when the original boiler was coal-fired and didn't have electrical controls. It has a float and trip-switch inside, so if the pressure in the boiler ever increased, water would back out into the returns, closing a set of check valves, then rise into the chamber, lifting a valve to allow steam into it that would push the condensate back into the boiler.0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
