What is this?
Matthias
Member Posts: 38
That looks like a TRANE Direct Return Trap for a two-pipe steam system. It was used when the original boiler was coal-fired and didn't have electrical controls. It has a float and trip-switch inside, so if the pressure in the boiler ever increased, water would back out into the returns, closing a set of check valves, then rise into the chamber, lifting a valve to allow steam into it that would push the condensate back into the boiler.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
