Old School /New Boiler Install
NYC007
NYC007 Member Posts: 15
edited February 2015 in THE MAIN WALL
Queens, NY, 2013 -1 Pipe -Old Boiler Cracks in November- I call a Supposed heating contractor, someone I know (Bad Move) -to install a new boiler in multi-family unit. Job is done -Since then it takes 1 1/2 to heat up building-5 contractors later everyone has different views how to fix or make it better. This past December, I'm in the Boiler room, talking to the boiler- sitting and staring at the unit and question pops up -My grandmother used some fandangle pressure cooker for something, I used to stare at the thingy on top wiggle as steam came out,WHY isnt this Boiler piped from the Top ? Im by no means a Heating guy, but learning fast. I call SMITH and ask , "Why do you guys make a boiler with a pipe out of the side-They reply "WE DON'T" , thats for a water Jacket" -HOLY !%#@$^^!% was I pissed ! How could this Heating contractor do this -The guy has been plumbing for 20 years!!! and got paid- Well i called him to look at it and casually told him it was done wrong if he could fix, a "mechanic" a helper (who couldn't even pipe dope a fitting) and myself - Not only do they create a 15" Steam pipe to the Header because "They didn't have room, but soon after he wanted $1000.00 for the job -I bought all material ($1800.00) - Well now I get heat 15-30 minutes later -The intense Surging on the sight glass is done-I couldn't even hook the secondary low water cut off on, because the water would vanish and kill the boiler-Thinking back I went through 3 relays, from on off on off on off on the burner. To date he can't admit he ___cked up, and "No problem we'll fix it", he wants his $$ -and adamant about it and WANTS CASH payment lol... He did say to me "This is why I don't do work for friends", I replied "YES, I SEE WHY ITS BECAUSE YOU LOSE EM ALL-- I did say I would cover his expense for his workers, the supposed friendship is shot at this point, Your opinion ? This poor Boiler btw -Smith voided is warranty :(
  • KC_Jones
    KC_Jones Member Posts: 5,926
    According to their website that unit can be used for steam.
    http://www.smithboiler.com/html/19he-heating-boiler.asp
    Why did they void the warranty? If you are looking for help on how to fix what you have post some pictures from a little further back so we can see all the piping. Is this a one pipe or 2 pipe system?
    2014 Weil Mclain EG-40
    Jamie Hall Member Posts: 27,195
    Oh wonderful. If it cheers you up any, that is not the first time I've seen a boiler which can be used either for water or steam, depending on how it is piped and controlled, piped as though it was for hot water but installed on a steam system. It didn't work any better the last time I saw it, either.
    It's just. plain. wrong. And, piped as it is, you will never get it to work properly.
    NYC007
  • NYC007
    Yes, it can be used for Steam or Hot Water -In that Picture they pipped from a 4" cap that is used for Hot Water Application, not for Steam Application-The Steam is from the Top of the Boiler
  • NYC007
    Is This Low Water Cut Off Correct ? Thoughts ? *KC-Jones Yes I will get more Pics -Thank you !
  • JStar
    JStar Member Posts: 2,752
    What exact model is the boiler? How many sections? You may be able to swap out one or two sections to include top tappings to be used for steam.
  • NYC007
    I will let you know and show updated pictures Joe I believe its 4 section HB Smith -Again, they did cap off that 4" port and pipe 3" from the Top-pics coming soon~
