low water cut off
teresad
Member Posts: 4
is there a minumum suggested distance between the primary low water cut off and the manual reset lwco?
if too close and system surges have had some problems tripping manual reset. thaks
LWCO distance of separation should not be a problem. What maybe happening is a spike in pressure from a faulty pressuretrol/pigtail could be pushing enough water out into the returns, causing a temporary low water condition. alternatively, the probe [or the water] may need cleaning.
Install a low pressure gauge, on the same [newly cleaned] pigtail with them, keeping the useless 0-30 psi gauge, and verify your pressure.--NBC0 -
Is this a new boiler? It could also need a good skimming if it's newer or has recently had work done. This can also cause the surging. I agree with NBC sounds like a surging problem not a LWCO problem.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
